Idle Air control vlave
Old Oct 7, 2013 | 01:27 PM
Gras's Avatar
Anybody knows where I could find an Idle air control valve part number 22230-3015, for a 86 4runner 22RE ?
Old Oct 7, 2013 | 02:32 PM
wyoming9's Avatar
Red face
Well if you can no longer get it from the dealer your going to need to hunt for a used one.
Old Oct 7, 2013 | 03:10 PM
Stetson_md's Avatar
Oreillys has it for a 91 pickup with a 22re $109 for a stick shift $176 for auto
Old Oct 7, 2013 | 05:54 PM
BigBluePile's Avatar
Is it bad or do you need to adjust it?
Old Oct 8, 2013 | 03:54 PM
osv's Avatar
osv
don't even look for a replacement, it's a junk design.
swap the throttle body/plenum for the later 22re hardware, you'll lose that valve entirely, and the truck will run better.
Old Oct 8, 2013 | 04:18 PM
rworegon's Avatar
Me thinks you are missing a digit in the last of the part number.
Old Oct 11, 2013 | 03:59 PM
Gras's Avatar
Hi All,
- The current Iacv does not operate ( tested at high and low environment ).
- the correct part number is 22230-35010
- OSV could you be more explicit on the Throttle/Plenum replacement?
Old Oct 11, 2013 | 04:34 PM
osv's Avatar
osv
try these links:
http://siestaoffroad.com/tbody.html
http://www.pirate4x4.com/forum/toyot...take-swap.html
Old Oct 11, 2013 | 06:19 PM
Gras's Avatar
Thanks OSV, While the swap is more involved than a IACV change, I will have to consider it if I do not find any other solution.
Old Oct 11, 2013 | 06:40 PM
osv's Avatar
osv
it's not as bad as it looks... hassling with the tps swap was the most irritating part of it for me.
you can use the accelerator cable that you already have, just take a die grinder to the last 1/16" inch or so of the cable, leaving enough plastic on the cable end it to fit it into the barrel piece that has the set screw.
i got a pack of various barrels at pep boys, and drilled out the diameter of the smallest one, it fit fine.
you can use the lower section of the intake manifold that you already have, you don't even have to remove it, just take off the upper plenum only.
Old Oct 11, 2013 | 06:41 PM
osv's Avatar
osv
the cold start improvement is what makes this worthwhile... it passes california smog.
Old Oct 11, 2013 | 09:38 PM
Gras's Avatar
OSV - Thanks for the additional info
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
coryc85
Sep 9, 2015 06:24 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
sojourner567
Jul 16, 2015 08:52 PM
