How to remove ANY crankshaft pulley bolt
Old Mar 26, 2009 | 09:03 AM
PowellTacoma's Avatar
I happen to know the super secret method to do this.
I will share this with you only because I too once felt your pain.
(Please note this method actually works even better with the motor out of the truck.)
A) Purchase a 12" lady's foot - http://www.harborfreight.com/cpi/cta...emnumber=31382
B) Purchase a strong breaker bar with the correct sized 19mm impact socket.
C) Go to your local home improvement store and purchase a 3-6ft long aluminium fence pole to slide over the breaker bar. (make physics work for you)
D) Either pull your oil pan and have someone place the lady's foot up in the the block or remove the engine and turn it over so it looks like this:
E) Place the lady's foot where the line is so the balancers/crank will rotate around and stop on it. This will keep the crank from moving without hurting, denting, scratching, or breaking anything.
F) Next just put your fence pole on the breaker bar and slowly turn until it breaks loose.
Hope this helps and Good Luck!
Old Mar 26, 2009 | 09:18 AM
algranger's Avatar
Hmm not bad
Old Mar 26, 2009 | 12:07 PM
annoyingrob's Avatar
I'm lazy, and usually put my 3ft breaker bar on the bolt, rest it on the ground, and crank the starter.
That, or I put it into fourth gear, have a friend step on the brakes, and use my 3ft breaker with a 4ft pipe on it.
Old Mar 26, 2009 | 12:25 PM
Brent7mRunner's Avatar
breaker bar with a pipe against the frame and juice the starter works 9/10 times, unless its a honda and the engine spins the other way
Old Mar 31, 2009 | 12:35 PM
becaron's Avatar
I made a crank pulley tool from a piece of pipe and a block of steel. It takes some effort to make, but it's easier to use than taking the oil pan off and putting a bar between the block and crank.
I'll look for pictures.
Blamalam
Mar 12, 2022 07:34 AM
TJWilly
Jul 31, 2015 02:05 PM
yoterr
Jul 24, 2015 04:29 AM
dinks07
Jul 15, 2015 05:34 PM
Snort
Jul 9, 2015 03:58 PM
