Hot start issue
Old Mar 21, 2017 | 05:53 PM
Dizy85's Avatar
5 Year Member
Hot start issue
Ok, so have to say i am new to toyota's from jeeps. I bought a 85 4x4 from a kid that put on a 36/33 weber. So far i have removed all smog equipment, and replaced intake and exhaust gaskets, plus tune. He also had the return from fuel pump going to the vent tube on the tank, which is now fixed. I am having a issue restarting the truck after it has warmed up and i stop at store or something it will not restart unless i press gas pedal to the floor. I have searched but have not had much luck. Before i fixed the vent line i figured the pressure in tank might have been forcing gas past the floats bit it still does it after fixing vent. Any help wluld be appropriated
Old Mar 21, 2017 | 06:45 PM
L5wolvesf's Avatar
Presuming you have a Weber 32/36 . . . and reading "forcing gas past the floats" made me think of fuel pressure. Is there a pressure regulator on the fuel line?
Old Mar 21, 2017 | 07:10 PM
Dizy85's Avatar
5 Year Member
I was thinking that also, i have a regulator just need to get a gauge . Jusy wanyed to get it out there to find out if iy could be anything else
Old Mar 21, 2017 | 07:29 PM
L5wolvesf's Avatar
Some regulators have a marked setting on them, so you don't necessarily need a gauge. A picture is worth 999 words.
Old Mar 21, 2017 | 07:31 PM
Dizy85's Avatar
5 Year Member
Its a holley regulator that comes with a holley blue pump. Its brand new i was going to install it in a 79 F150 i had.
Old Mar 21, 2017 | 07:38 PM
L5wolvesf's Avatar
I'm not positive but that may not adjust down to 2.5 psi. That pump is definitely way more than is needed.
Old Mar 21, 2017 | 07:51 PM
Dizy85's Avatar
5 Year Member
I will see it is just something i already had on hand. I dont plan on useing the pump
