Help Plz Strange Problem
Old Nov 3, 2008 | 02:42 PM
eatmorechicken's Avatar
I have an 85 22re 4runner. I blew up the motor that was in it when I got it and dropped a used motor it it so the only things that have changed are the block and the head. The original motor ran perfect. I'm getting codes 6 and 10. The problem is that the first time I take off every time I start it, its really sputtery around first and second gear till I wind it to 3500 rpms or so (like its starving for gas), but it still does it even if i cycle the key a bunch of times. It only does this ONCE each time I start it. It doesn't matter how long it sits when I turn it off, 5 minutes or 2 hours, it still does it, although the longer it sits the worse it is it seems. Thats all the info I can think of right now. I'v been trying to figure this out for 2 months now and its driving me nuts. Any ideas?
Old Nov 3, 2008 | 02:48 PM
olharleyman's Avatar
did you check for vacume leaks?
Old Nov 3, 2008 | 02:49 PM
scuba's Avatar
Check you plugs and wires and their boots, if those are cracked they can spark to the block.
Check your grounds in the engine bay...
And i dont believe there is such thing as codes 6 and 10...
Old Nov 3, 2008 | 02:50 PM
fireman1559's Avatar
when was the last time you had a tune up and check to see if you have a fuel presssure regulator somewhere under the hood that might need to be
Old Nov 3, 2008 | 02:52 PM
stagger_lee's Avatar
Check your timing. MIght need to be advanced a bit. How long did it sit before you swapped the motor? Sometimes a fuel pump can go bad if it dries out or sits too long. Mine died in a month one time. I would check that first, then plugs and wires, then grounds, and then timing.
Old Nov 3, 2008 | 02:58 PM
1986ToyTruckOMM's Avatar
Vacume leak maybe
Old Nov 3, 2008 | 03:04 PM
HupDogDaddy's Avatar
I aint no expert but it sounds like it is only doing it when the engine is cold?
possibly a bad thermo vac valve ?
Just an idea
ghostmoney
Jan 28, 2018 11:42 AM
Esibnitsud
Jul 21, 2015 08:51 AM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
ryerye13
Jul 14, 2015 08:27 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
