Hard Starting
Old Nov 5, 2009 | 07:12 PM
wannagetrdone's Avatar
Hard Starting
Ok Im not sure whats causing this, but Im thinking starter maybe. When I try to start the truck it turns over and hickupps but not try to start, its like the engine binds down it seems to be in a rhythm. The starter is fairly new, timing is not advanced too far and my battery is charged. What yall think? The truck will start ok when it gets turning over fast enough.
Old Nov 6, 2009 | 04:00 AM
Team420's Avatar
the fsm points to the ac signal circuit for slow cranking.
http://www.ncttora.com/fsm/1990-1995...e/troubles.pdf
Old Nov 6, 2009 | 01:22 PM
the tab attached is for a 3vz engine not the 22r and what is the ac signal circuit? thanks team 420
Old Nov 6, 2009 | 01:33 PM
toyotabull's Avatar
have you pulled the plugs to see if it will turn over faster, and check your ground from frame to motor.
skoti89
Jul 8, 2015 12:05 AM
bryan34w
Jul 6, 2015 05:53 PM
colinmil
Jul 6, 2015 04:03 PM
coryc85
Jul 6, 2015 04:07 AM
karbin
Jul 5, 2015 11:37 PM
