Hard Starting??
Old Sep 27, 2007 | 01:40 PM
CrackerToy's Avatar
Hard Starting??
So I've had this 85 4-Runner for a couple month's and I have tried the best types of fuel injector cleaner, and replaced the fuel filter and I am still having problems w/ starting it and it bogging down when I gas it. Also have put a brand new battery in it JUST to make sure. NOTHING! Can someone give me some tips? Possible solutions?
Old Sep 27, 2007 | 07:44 PM
myyota's Avatar
Try replacing the fuel filter
Old Sep 27, 2007 | 07:48 PM
nathan751's Avatar
Mine does the same even after new plugs, wires, cap, rotor, good floggings, o2 sensor.
I'll be curious to see what is said.
Old Sep 27, 2007 | 07:49 PM
ozziesironmanoffroad's Avatar
check your TPS. also check your cold start injector. do a compression check as well.
Old Sep 27, 2007 | 07:50 PM
WI_Mike's Avatar
A new O2 sensor fixed it for me.
Old Oct 7, 2007 | 07:33 PM
CrackerToy's Avatar
Only I problem is I kinda need a diagnostic I guess b/f I go buying a bunch of parts I don't need. It's weird, if it has sat all night it'll crank right up in the morning, but if it's sat anywhere from 30 mins to 3-5 hrs it'll try's and try's to turn over and after a more than significant time it'll will sort of roll over into start mode, idle lower than normal for a few seconds and then come up to operating rpm's, weird.
Old Oct 7, 2007 | 08:26 PM
rowdy235's Avatar
If i recall i think 4crawler had the same problem- Here is some information on it, the real problem and and easy fix:
http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
skoti89
Jul 8, 2015 12:05 AM
bryan34w
Jul 6, 2015 05:53 PM
colinmil
Jul 6, 2015 04:03 PM
coryc85
Jul 6, 2015 04:07 AM
karbin
Jul 5, 2015 11:37 PM
