Hard to,find ..84 air cond. idler pulley
Old Apr 30, 2017 | 04:59 PM
DAYLEY/CHALLENGER's Avatar
5 Year Member
Hey, new and first post. Have a 1984 SR5 Extra cab, 4wd, with 22r engine. 291,000 miles.Air conditioning pulley making a little noise so started looking for one. Only luck so,far is in Australia . Not available from Toyota so,said the dealer. Have any of you guys had better luck? As I get into the forum more I will post some pics and more stories about my truck. Thanks in advance for any info.
Old Apr 30, 2017 | 05:01 PM
millball's Avatar
Isn't it possible to change the bearing in these?? It is a common bearing if I recall correctly.
Old Apr 30, 2017 | 06:02 PM
gsp4life's Avatar
Are you talking about the a/c tension pulley or the pulley on the compressor?
Old Apr 30, 2017 | 06:22 PM
5 Year Member
Should have been more specific....yes it is the tension pulley. And as far as changing the bearing, it's actually a double bearing and is staked in the pulley. I thought about,changing but looks to be a precision press in and stake in 4 spots. I just don't have the tools for that. The pulley has a 15mm hole. I can find plenty of pulleys with the 12 mm hole but only one with the larger one. And as I said, it's in Austraila.
Old Apr 30, 2017 | 06:27 PM
millball's Avatar
I found this on Ebay:
http://www.ebay.com/itm/Gates-A-C-Drive-Belt-Idler-Pulley-fits-1984-1995-Toyota-4Runner-Pickup-Van-T100-/222491879135?fits=Year%3A1984%7CMake%3AToyota&hash =item33cd8ca6df:g:tGcAAOSwmfhX3uqk&vxp=mtr
Might be similar ones cheaper
gsp4life's Avatar
I was irritated by the way Toyota used a staked bearing pulley as well. I found a replacement from 22reperformance. It was $30 or so. Just give them a call and they'll be able to help you.
Old Apr 30, 2017 | 06:45 PM
old87yota's Avatar
x2
22RE Performance sells them. The description says that the pulley fits all 22R/22RE engines but I would give them a call just to be sure.
They are in the process of upgrading there website but here's the link: https://www.yotatruckparts.com/22re-...djuster-pulley
Note: They are not shipping any parts next week (see banner at top of website).
Old Apr 30, 2017 | 06:46 PM
5 Year Member
Thanks GSP. Will investigate that. Millball, that bearing appears to be one of the 12mm shaft style. And is different from the original. But thanks for looking .
Old Apr 30, 2017 | 06:52 PM
5 Year Member
Thanks Old87, it appears that I will need to replace the complete Assy. And not just the pulley. Will call these guys this week.
Old May 23, 2017 | 11:10 AM
reelal's Avatar
AC pulley
I got one for my 85 4 runner from rockauto. Looks like original.
Old May 23, 2017 | 02:22 PM
strike2x's Avatar
Tensioner pulley
I have a tensioner pulley assembly I took off my 87. I don't know if it would work. It came off the lower right side by the motor mount. May work if interested in it.
Old May 25, 2017 | 02:05 AM
strike2x's Avatar
If anyone needs AC parts text me at 9894225142. I took it all off my 87 pickup because I live where it is not needed but maybe a week a year.... Willing to sell or swap any or all for something I can use.....
Old May 26, 2017 | 03:46 AM
5 Year Member
Ok...........just ordered the pulley from 22RE...........will see how it works out...........Thanks for the help guys...........
Old May 31, 2017 | 07:53 AM
5 Year Member
Had a chance to put on the new pulley from 22RE..........works great and now I have air again........good timing too........
Haven't had a lot of time to view a lot of this forum but so far........there seems to be a great group of guys here and some very smart ones too..........rebuilds, etc gets pretty deep..........good to know where to come for info.................thanks again for the leads.........as I looked at the pulley in Australia again and the freight was over $40....no go on that one for sure...........David
