going 4wd to 2
Old Sep 17, 2006 | 03:34 PM
ronniedaniels's Avatar
going 4wd to 2
i have manual lock in hubs on my 86. when i am in 4wd and try to go back to 2wd its very difficult. i have tried reverse first, unlocking the hubs first, but its still difficult. eventually it goes after snatching around on the lever some. will changing the fluids help? any other advice?
Old Sep 17, 2006 | 05:26 PM
rdlsz24's Avatar
I always turn the hubs to FREE first, and then shift back into 2WD. Most of the time it goes into 2WD very hard, but I find rolling forward slowly while trying to shift back to 2WD seems to help. I don't think changing the fluids will help, since I have fresh fluids in all my cases and it doesn't make a difference.
Rob
Old Sep 17, 2006 | 05:33 PM
4Crawler's Avatar
Just make sure to shift out of 4WD while moving straight ahead and while on a loose surface, like dirt or gravel. What you are feeling is normal driveline binding caused when the front and rear axles/tires travel a different length, like while turning. You may also have slightly different size tires front and rear that can make the binding worse. I try to shift out of 4WD before leaving the trail, on a flat stretch of road and just let off the gas a little (neither accelerating nor engine braking), while holding a light forward pressure on the t-case stick. It should pop out easily, no need to force it. If you try to shift out after a turn, try reversing the direction of the turn while shifting. That is if you made a sharp left before shifting, try either making a right turn (forward) or left turn (in reverse) to unload the driveline before shifting.
kawazx636
Oct 6, 2021 03:03 PM
Daenerysdad
Oct 1, 2015 07:33 PM
tylermx71
Sep 29, 2015 08:49 PM
Cycles
Sep 29, 2015 06:37 AM
May-39
Sep 6, 2015 01:05 PM
