Front Leaf Springs?
Old Jun 14, 2008 | 07:22 PM
boice1971's Avatar
Front Leaf Springs?
I've been searching the forum for information on replacing the front leaf springs with stock/no lift springs because I thought mine were worn out. Some of the stuff I keep reading leads me to believe that the factory front springs do not have much arch and are even close to flat. Is this true, can someone clear this up for me? If it is true that they do not have much arch, does anybody have the add-a-leafs on the front? My tire to fender clearance is about 1" less in the front than the back and I'd just like to fix that. This will probably only be a temporary thing as I want to ditch my 3" body lift for a 1" BL and a 3"-4" suspension lift; I just don't have the $$$ for that at the moment.
Old Jun 15, 2008 | 01:09 PM
85toy's Avatar
yes they are basically flat from the factory.
Old Jun 15, 2008 | 01:14 PM
4Crawler's Avatar
Yep, stock fronts are basically flat even reverse arched:
http://www.4crawler.com/4x4/4R_suspension.shtml#PhaseI
Add a leaf is trick up front as you need to maintain clearance for the steering drag link to clear the springs and u-bolts for proper steering. I was never able to get more than 4 leaves in mine (note stock springs are 4 leaves), so you might be able to swap some leaves around. Of get a 2" lift spring from OME.
Old Jun 15, 2008 | 05:22 PM
boice1971's Avatar
Thanks, I feel alot better now. I'll just wait until I have money for a lift and gears, I'd like to go up to 35's or 36's
Old Jun 16, 2008 | 10:53 AM
Al's Chop Shop's Avatar
mine are inverted, but i figure they were flat when new. only about an inch to and inch and a half clearance between the springs and the bump stops... makes for a really crappy ride!
Al
Old Jun 20, 2008 | 10:55 AM
Volcom's Avatar
My stock front springs are flat out of the truck and no weight on them and looked 4crawler's while under the truck
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
shisha1999
Sep 21, 2015 08:22 PM
coffey50
Jul 28, 2015 10:55 AM
Nickdigg
Jul 7, 2015 06:04 AM
