front leaf spring hardware
ok, in the process of putting on the leaf springs.. (have about 20 hours into a lift that should take 2) I have totally roached the front bolt/nut contraption bs on the front leaf springs. Would it be kosher to use similiar sized SAE Grade 8 hardware from the local Screw-Value?
Yes, the spring pin is 18mm in diameter. You'll need to either weld the large size hole in the spring hanger in with an 18mm hole in it, or reuse the flange from the stock pin with an 18mm bolt. Or you can get replacement pins from some of the on-line parts places.
Or just make up a new spring hanger:
- http://www.4crawler.com/4x4/CheapTri...ringHangerDrop
And then you can use plain old bolts:
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
