front end diagnostics
Old Apr 16, 2013 | 08:32 AM
colorado85pu's Avatar
When there is play in the wheel, is there a way to distinguish between worn wheel bearings vs trunnion bearings?
Old Apr 16, 2013 | 08:41 AM
Tyman187's Avatar
I know a Wheel bearing will have equal play all round the tire Up Down Left right. about ther other im not shure,
Old Apr 16, 2013 | 09:22 AM
4Crawler's Avatar
Yes, lift the front tires off the ground then grab at 6- and 12-o'clock and give it a good tug. Repeat at 3- and 9-o'clock. If more play felt at 6-12, then likely the knuckle or trunion bearings. If equal play, then likely wheel bearings. If more play at 3-9, then could be worn out tie rod ends. You can also put a pry bar under the tire and lift and lower and look behind the wheel to see what is moving. If you see the knuckle rocking in and out, then it is probably those bearings.
Old Apr 16, 2013 | 01:49 PM
ojm3's Avatar
If you have manual steering there is an adjustment for the worm gear in your steering box. The side has a locking nut, loosen it and adjust the screw to your liking them tighten the lock nut
Old Apr 17, 2013 | 12:56 PM
Rusto's Avatar
"If you have manual steering there is an adjustment for the worm gear in your steering box. The side has a locking nut, loosen it and adjust the screw to your liking them tighten the lock nut"
This really helped tighten up my steering and took about 5 minutes. I still need to tighten up/replace a wheel bearing, but it's much better.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
Daneums
Aug 20, 2015 05:36 AM
