front axle seals
Old Aug 15, 2014 | 04:19 AM
puddlepirate's Avatar
front axle seals
So I wanted to ask how long does it take for say a shop to replace the front axel seals? I'm asking because I haven't had the time lately to crawl under there and do it myself so I was thinking I could have a shop do it for me depending on how much it would cost. Would anyone have an idea on time and price? Also if the shop isn't within my budget and I do do it myself does the entire knuckle "assembly" have to come apart or can it be pulled mostly as a unit?
Old Aug 15, 2014 | 08:33 AM
FrankTorres's Avatar
I'm guessing a shop could charge you up to 6-8 hours labor to do it right...
Old Aug 15, 2014 | 08:36 AM
MaK92-4RnR's Avatar
There's many write ups, tools required, torque specs that a beginner with no skills at all could do it.
No the knuckles don't need to come off, the axle seal is on the spindle.
Old Aug 15, 2014 | 05:00 PM
scuba's Avatar
I think he means the inner axle seal. Not the hub seal.
I would think a shop would charge around 4-6 hours of labor.
FYI, if you do the job by the book, it would be a good idea to put in new wheel bearings as well as all the brakes and all of the seals and gaskets.
However, if you use the "Camo Method" of removing the knuckles, you won't have to reset the wheel bearings or touch the brakes.
Old Aug 15, 2014 | 05:57 PM
JasonYota's Avatar
OP which seals need replacing? Inner axle seal as in the backside of the rotor/hub assembly or the axle seal on the front differential?
Old Aug 16, 2014 | 10:21 AM
I apologize I was meaning the inner axel seals. They are beginning to leak a little. I've been finding grease on the tires and in my driveway . By grease I mean gear oil
Old Aug 16, 2014 | 10:52 AM
On the back side of the rotor/hub
Old Aug 16, 2014 | 11:42 AM
JasonYota's Avatar
Toyospear's write up on this job is a very good one. It's on here somewhere.
88sasturbotoy
Jan 30, 2026 01:57 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jasonty
41
Dec 23, 2018 01:00 PM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
