front axle brake upgrades
Old Nov 27, 2016 | 06:07 PM
az1320's Avatar
so I have been searching over the sit for a few hours now and I cant find any threads about brake ungraded from stock front axles to something better. anyone have a link for one or some sort of cross over list?
Old Nov 28, 2016 | 03:12 AM
arlindsay1992's Avatar
1990-1995 Toyota 4Runner V6 calipers, pads, master cylinder, and brake booster
1985-1989 Toyota Landcruiser rotors
You'll have to clearance the splash shield for the bigger caliper. Also check clearance between the back of the wheel and the caliper.
Old Nov 28, 2016 | 02:19 PM
osv's Avatar
osv
i run a t100 dual-diaphram large diameter booster, it bolted right in, along with lc rotors and v6 calipers.
here is another variation, using the weaker single-diaphram large diameter booster, and t100 rotors/calipers: http://www.expeditionportal.com/foru...955#post849955
the numbers that are cast on the side of the calipers are important, for identifying what you have.
