Fried wires. Truck won't fire
Old Mar 8, 2014 | 02:50 PM
PAgrown's Avatar
I had a mess up today. Thinking I could wire in a ammeter... Well turns out I didn't know how to wire it in. I spliced the gauge to a hot wire from the battery to the rack lights saw a bit of a spark when I tried putting the neg battery cable but said screw it and forced it on. Truck started smoking the pos neg wires on the ammeter. I can't see any other wires burned except for this on wire to my rack light and it's not even burned just melted the insulation. Anyways my truck works entirely except it fire, the starter turns I can hear the fuel pump with the key on, just won't turn over! I tried spraying ether into the airbox but to no avail. I'll check for spark tomorrow, and does anyone know how to test to see if the injectors are working?
Old Mar 9, 2014 | 05:39 AM
wyoming9's Avatar
Red face
Did you check that you didn`t blow any fuses??
Most gauges come with instructions.
I could never see a use for a ammeter except to read current draw Give me a volt meter any day.
Old Mar 9, 2014 | 09:12 AM
PAgrown's Avatar
I incidentally lost the instructions... I checked a fuses last night in the engine bay. Time to check down in the drivers side. But the truck still wants to run she just won't fire!!!
Old Mar 9, 2014 | 09:38 AM
PAgrown's Avatar
Fuses all look good... Dammit. and I realized I don't know how to check for spark plug fire by myself...
Old Mar 9, 2014 | 09:45 AM
wyoming9's Avatar
Red face
It can be a little hard without a remote starter switch.
Old Mar 9, 2014 | 09:51 AM
PAgrown's Avatar
And just realized I've been using carb cleaner not starter fluid.....
Old Mar 9, 2014 | 12:54 PM
PAgrown's Avatar
So me and my mechanically inclined friend went through and checked the ignition coil, checked out good, the wires are giving power from the ecu, he's suspicious about the igniter on top of the ignition coil though as a possible problem, he's a professional mechanic and says we were thorough and its probably just a freak thing that I'm not getting spark. Any additional input anyone?
Old Oct 15, 2014 | 09:27 PM
pewdiepie's Avatar
relays
Op, i had the same problem you did, but it had to do with my amp, i accidentally wired the ground to power and power to ground, thank god the fuses blew until i found out the problem i made. Anyways to the point, i think a fuse is the culprit, since you said you checked them and they are all good, have you checked the relay's? most likely one of the relay's are fried. i burned out my headlight relay once and i couldn't use anything. weird coincidence but it happend. Check your relays and check the wiring that lead from the positive side to the fuse box, check if there ok.
DacodaYota
Sep 2, 2015 02:13 PM
bigblue82
10
Jul 6, 2015 08:27 AM
ibayne
Jun 26, 2015 06:30 AM
newzingo
Jun 24, 2015 01:50 PM
