First post and I'm already in a pickle...
Old Sep 7, 2012 | 04:41 PM
StumpyJohnson's Avatar
Yep, I'm that guy...
You know, the dude that joins a forum and his first post is a cry for help.
I need to know what this bracket is for and where it goes.
Whelp, turns out I don't have permissions to add an attachment yet. Anyways it's 'y' shaped, with a hole at its leg, a hole at the upper right arm of the 'y' and a nut welded to the back of the other arm which is threaded to receive a short 8mm bolt. I took a lot of pics, I've scoured the fsm, the haynes and chilton books and I can't figure it out. Maybe I need to step away from the truck for the first time in a week.
Since its my first post I'll give you a bit of background about me and the truck. I recently purchased an 84 extra cab, carbed, in great shape for $2700. It had 84k original miles, the interior is perfect and it ran great. But! The old man I bought it from never drove it. So after a month of leaking a bit here and there she finally blew the rear seal. So I put a timing kit, new gaskets throughout, both seals, an new clutch in it. It needs a few things, front axle rebuild for one, but it's practically brand new. I love it, but this bracket is killing me.
Help appreciated, pics will be forthcoming.
Old Sep 7, 2012 | 05:04 PM
85TurboRunner's Avatar
Its the power steering pump support bracket. The bottom hole on the y connects to the front of the engine and the top hole goes to the pump bracket. Don't have a pic but its pretty easy to figure out.
slacker's Avatar
power steering pump support bracket .. search that , and you'll find lots of pics
Old Sep 7, 2012 | 05:30 PM
Yea i found it by the empty hole in the face of the block after I posted, and then played toyota tetris from there...thanks regardless. Sorry my first post was a cry for help, I normally have better manners.
Old Sep 7, 2012 | 05:46 PM
NickMiller's Avatar
Don't worry about it! Welcome to the forums!
