EFI Question
Old May 19, 2006 | 07:05 AM
RTA's Avatar
RTA
Question EFI Question
I Have A 22re That I Cannot Get Started. Please Help With Any Ideas !
Truck Was Running Then Tore Up The Crank. Unbolted Head And Intake Rolled To The Side And Replaced Block. Put Everything Back Together And Motor Turns Over But Will Not Start!
Checked All Wires, Grounds, And Connectors. I Have Fire To The Plugs, Gas To The Injectors. The Injectors Are Not Opening. I Have Replaced The Circuit Opening Relay And A New Computer. Injectors Are Getting Power But No Ground After Engine Is Being Cranked.
Old May 19, 2006 | 07:49 AM
AH64ID's Avatar
Check your block to chassis ground.
Old May 20, 2006 | 10:45 AM
RTA's Avatar
RTA
Already cleaned and sanded all of my grounds.
Old May 24, 2006 | 01:50 PM
darth brian's Avatar
check to see if your stock alarm system/killswitch thingie is turning on with out you knowing. or see if you have one. i didnt know i had one until my truck wouldnt start and i had to take it out and rewire it to bypass and never had to worry about it since
Old May 24, 2006 | 07:51 PM
superjoe83's Avatar
the computer grounds the injectors to fire them, if its not getting the signal from the dist/igniter, then it wont fire, are you sure you plugged everything back up, especially the 3 wire harness that goes from the igniter over to the passenger side
daddio
Aug 9, 2015 07:17 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
