Dropping oil pan 3VZE, what else should I replace?
Old Mar 5, 2020 | 06:43 PM
68jimmy's Avatar
All, over the past few weeks I've been posting my journey to replace the failed clutch along with the rear main seal. (https://www.yotatech.com/forums/f115...-plate-310046/) Since I've been unable to remove the rear main seal retainer, and figured it would require dropping the oil pan. Today, I dropped the front diff along with the drag link and before I drop the pan what else should look at replacing while I'm in there? So far the vehicle has 318,000 on the clock and I'm sure there are a number of items I should address while I have it open...
Thanks in advance!
d.
Old Mar 6, 2020 | 03:55 PM
68jimmy's Avatar
After dropping the pan, oil pick-up and baffle I noticed a small gasket for the pick-up tube. No gaskets were used for the pan/baffle just FIPG between all surfaces... I'll check with napa for the oil-pickup tube gasket.
YotaRiley
Jan 25, 2011 08:35 AM
simpsons721
May 3, 2008 11:03 AM
jerbear
Nov 5, 2006 06:27 PM
NathanBERG
Jan 4, 2005 02:03 AM
