Driveshaft flanges
Old Jun 27, 2011 | 09:24 PM
kckay's Avatar
Driveshaft flanges
'85 4Runner, 5sp - 5" AllPro lift. Rear driveshaft broke at the transfer case U-joint. This destroyed the driveshaft. Found a replacement shaft at an auto-recycling center; it has '86 Turbo and '88 SWB painted on it. The length measured right.
When I tried bolting it in, the bolt holes in the flanges on the driveshaft are 1 cm wider then the flanges on the rear 3rd member and transfer case.
A Toyota off road specialty shop indicated that Toyota will not sell the flanges separate from the driveshaft.
How have other solved this problem?
Where can I get flanges that are the correct size bolt pattern?
Old Jun 27, 2011 | 09:55 PM
justin_4runner's Avatar
if the flange is still good cant u just pull the flange and swap it with the old one? then it should bolt in. also are the bolts pressed in on the flange? i had an issue where it wouldn't line up and go on so i pushed out the studs and it ended up fitting and bolting together just fine.
Old Jun 27, 2011 | 10:13 PM
Mr.Utah's Avatar
If all else fails, bore out the holes slightly larger, barely enough to fit, then bolt them on. Use some good sealant between t-case and differential. I would try this before getting a new pricey drive shaft?
Old Jun 28, 2011 | 04:27 AM
waskillywabbit's Avatar
Buy some triple drilled flanges that have all the bolt patterns. Done.
:wabbit2:
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
ToyotaMD
Aug 17, 2018 10:16 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
