Differential Oil Splash Guard Thing
Old Sep 28, 2012 | 07:41 PM
NicHoza's Avatar
Hello everyone. I am putting my truck back together, and I have a question for you. In the differential, there were two splash guard type things welded in place. However, one of them got mangled, as you can see in the picture.
I'm wondering if it is important to unmangle it and weld it back in place. It must have been there for a reason, but at the same time it doesn't look like it provides much of a seal, and I was wondering if anyone has any experience driving with them removed (did this cause problems for your rear axle/differential, or were you okay?)
Thanks for any info/advice!
Old Sep 28, 2012 | 08:10 PM
BigBluePile's Avatar
It's not welded in.
It's kinda like a windage tray.
Keeps the oil at the diff. Which is where it needs to be.
So, I'd recommend replacing it.
Old Sep 29, 2012 | 07:52 PM
NicHoza's Avatar
Hm. Not welded? I guess now that you mention it I see the tabs where it must snap in in the pictures.
What is that part called? Hard to replace without a name. I couldn't find it listed/pictured in my manual.
Old Sep 29, 2012 | 08:07 PM
It has a clever name in the FSM
Old Sep 30, 2012 | 10:34 AM
NicHoza's Avatar
Still couldn't find it in a FSM diagram, but I think I finally found it's name in the section titled "Install Rear Axle in Housing" where it says "When inserting the axle shaft, be careful not to hit or deform the oil deflector inside the axle housing".
So. Oil deflector. Couldn't find one online to buy. I was able to find this thread, which I found amusing: https://www.yotatech.com/forums/f114...ar-8-a-234397/
I guess I'll make my own.
Old Oct 1, 2012 | 01:37 PM
Staceman1's Avatar
Oil deflector? I have 2 in an old axle housing I am about to cut-up and throw away. Should I keep one set aside?
Old Oct 1, 2012 | 05:42 PM
NicHoza's Avatar
Thanks for the offer! Unfortunately I don't need it any more, as I already went to the trouble of re-shaping the orginal and welding it back together. You can't even tell the difference, right?
Old Oct 1, 2012 | 06:32 PM
Nice job!
Old Oct 2, 2012 | 07:19 AM
Staceman1's Avatar
Yeah, great job! That'll work just fine.
Old Oct 2, 2012 | 09:31 AM
rworegon's Avatar
Your repaired one looks great. They are still available from the dealer:
42139-40010 Deflector, Rear Axle Housing Oil
http://www.toyotapartseast.com/Page_...2235,2254,2255
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
Ladythump
22
Nov 9, 2015 08:53 AM
AaronM
Jul 8, 2015 07:15 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
