dash gage swap?
Old Apr 14, 2007 | 03:19 PM
simplypv's Avatar
dash gage swap?
my 85 has only the speedo gage and i would like to have a tach gage as well. i like the original factory look better than installing an aftermarket tach gage. what i want to know is, what would it take to swap my gage display? would i need the entire dash with the tach/speedo gage, or can i just swap out the gage display itself while keeping my original dash? is there any other difference between the speedo gage and the speedo/tach gage displays?
Old Apr 15, 2007 | 09:34 AM
simplypv's Avatar
14 veiws and no responses??? can anyone help me out please?
Old Apr 15, 2007 | 09:36 AM
89silverpu's Avatar
search for guage swaps with the search function. I know nothing about it but I know there have been posts like this before. BTW welcome to Yotatech
Old Apr 15, 2007 | 09:48 AM
simplypv's Avatar
89silverpu.. thx for the tips...
did a seach again but still couldnt find what i was looking for. i'll try to narrow my question down a bit. does any 84/85 trucks have a factory tach on the cluster display? if so, can it be straight swapped into an 85 truck to replace the speedo only cluster display?
Old Apr 15, 2007 | 10:09 AM
Yota Tony's Avatar
Look over on Pirate, there's a write up on an SR5 gauge cluster swap in the FAQ IIRC.
Old Apr 15, 2007 | 10:25 AM
DeathCougar's Avatar
just find an SR5 gauge cluster. Swap the oil pressure sender to the gauge style, then plug in the SR5 gauge cluster, and Viola!
btw...do NOT use a V6, or Turbo cluster as they will not just be plug and play.
Old Apr 15, 2007 | 10:26 AM
Heres one on Ebay with KM/h
Another with MPH
And another, for an Auto tranny
Old Apr 15, 2007 | 10:27 AM
the first one is in KM/h tho, if you can deal with Kilometers.
Old Apr 15, 2007 | 11:43 AM
fustercluck's Avatar
Deathcougar nailed it...
Old Apr 15, 2007 | 08:49 PM
runner4thebeat's Avatar
Does it matter if its from a manual or auto? I mean culd u put the the one from the third link to my manual truck?
Old Apr 15, 2007 | 08:51 PM
dunno. suppose you could, but the tranny light would not work, and you would not have a voltmeter.
Old Apr 16, 2007 | 08:45 PM
simplypv's Avatar
ok... so does it matter if i hook a cluster from an auto to a manual? would anything else have to change? also, will an inclinometer bolt up as well?
Old Apr 16, 2007 | 09:34 PM
toyaholic's Avatar
the only issue with a guage from an auto is that you will have an ect indicator that will serve no purpose instead of the battery voltmeter that comes on the manual transmission model. it will work fine other than that. you do not want a guage from a 6cyl, and if you have a 22r you will need a tach wire. no problems with an inclinometer either. there are tons of threads on this stuff, which is probably why you havn't had many responses.
Old Apr 17, 2007 | 07:46 PM
simplypv's Avatar
toyaholic.. thank you! any idea where i get a tach wire? do i have to pull it out of a junked rig or buy it new? hmmm.. i wonder what i can do in order to replace the ect indicator and make use of that space...
Old Apr 17, 2007 | 07:55 PM
toy power's Avatar
i think you can buy a voltmeter new from a dealership for about $50 if you really want it. but it would be easier to just get another from a mt truck. look around on this site and others for people parting out trucks. find a fsm, it will give you the pinouts for the connections on the back of the cluster. simply find the pin for the tack and see if there is a wire there. if not, like on my truck, splice into the capped off plug hanging off of the coil.
Old Apr 17, 2007 | 08:14 PM
the tach wire he is talking about just a regular wire run from the tach to the coil, nothing you can buy at the dealership. Some rigs need it, some do not. Wont really know until you plug the cluster in, and see if it works. My 86 4Runner did NOT need the spcial wire run.
Old Apr 17, 2007 | 08:24 PM
DudeBud's Avatar
thats because its a 22re. 22r's will need a jumper wire.unless they came with a tach cluster from the factory.
Old Apr 18, 2007 | 01:23 AM
85TurboRunner's Avatar
FWIW a turbo cluster will work fine.
Old Apr 18, 2007 | 06:44 AM
But you have a Turbo truck, no? Also, why does your truck have no oil pressure?
Old Apr 19, 2007 | 01:26 AM
i put that in before the truck was turbo, and i do have pressure but like an idiot i didnt change the sender so the gauge is shot.
