Crank shaft pully seal install
Old Jan 22, 2007 | 07:14 PM
Pa bowhunter's Avatar
Question Crank shaft pully seal install
I just replaced the seal and cant get the pully to go all the way back on. I thought that the bolt would take it back in. Is it ok to use the BFH on the end of the crank?
Old Jan 22, 2007 | 08:04 PM
NCSU-4runner's Avatar
its a tight fit but if even the bolt won't pull the pulley back theres something wrong. make sure both surfaces are very clean and you can try applying some lube to them. I've had trouble getting the pulley off several times but never putting one back on. The pulley is not meant to be beaten on, you can dent and even break it ( ask me how i know )
that seal is typically called the front main seal BTW
if you HAVE to try a hammer don't use a metal one, get a dead-blow hammer thats plastic at the front but has metal beads in the back to give it some energy on impact, and hit mildly around the edges in a circle and see if it goes on.
Old Jan 23, 2007 | 06:12 AM
Thanks for the reply. I found the problem. they gave me the wrong seal. I thought it was too good to be true that they had the seal in stock.
Old Jan 23, 2007 | 12:25 PM
surf4runner's Avatar
check to see if the seal will operate in the same poisition as the old seal...you dont want that...unless you polish the pulley where the old seal was.
i got a different thickness seal that contacted a different poistion on the pulley. no leaks.
Old Jan 24, 2007 | 10:37 AM
Got the right seal and every thing is good to go no leaks. Thanks
88sasturbotoy
Jan 30, 2026 01:57 PM
Amer
3.4 Swaps
19
Jun 5, 2017 10:43 AM
thefishguy77
Jul 30, 2015 10:59 AM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
