Clutch pedal popping sound
Also check where the pedal bracket is attached to the firewall. Not uncommon for the firewhall sheet metal to fatigue and crack there making the noises you describe before it ultimately breaks and your clutch stops working.
More info:
http://www.4x4wire.com/forums/showfl...t=1&PHPSESSID=
More info:
Tore into it and found the metal holding the pedals is in good shape, one thing I did note was the clutch pedal seems like it has got 1/4 to a 1/2 of side play. Not sure if this is normal since I have nothing to compare it to.
montanatruck
Feb 26, 2017 07:07 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
