charging circuit relay
Old Oct 25, 2009 | 06:08 AM
va slim's Avatar
85 2whl drive, 22r need to locate charging circuit relay, CANNOT locate, charge and brake indicator lights stay on, electric choke not working, charging OK, been driving for months. Looked behind both kick panels and glovebox, can't find anything marked charging relay, checked all fuses, help!!
Old Oct 25, 2009 | 06:28 AM
waskillywabbit's Avatar
Charge and brake lights staying on indicates bad alternator.
www.ncttora.com/fsm for an 85 Factory Service Manual
Old Oct 25, 2009 | 07:04 AM
swampfox's Avatar
have you checked the fuse ?
Old Oct 25, 2009 | 10:46 PM
86tuning's Avatar
relay is in the left kick panel, remove the trim panel and you'll see it.
Old Oct 26, 2009 | 12:48 PM
swampfox's Avatar
the charge fuse should be in the fuse box next to the battery. 7.5 amp ,it could be blown or not making good contact. i am assuming the truck is not charging .
Old Nov 1, 2009 | 01:22 PM
va slim's Avatar
Altenator wiring shorted out, after rewiring, the emergency brake and battery indicator lights stay on and the electric choke does not work. (battery is being charged, I've been driving like this for months!) All on same circuit by my book. Problem is "charging circuit relay", my problem is I can't find it. I've looked behind both kick panels and behind the glove box and undrer the hood. Book says it is marked "charging circuit relay" can you help? 1985 Toy p-u, gas, carb
Old Nov 1, 2009 | 04:31 PM
scott_co65's Avatar
Just pulled mine out yesterday. Unscrew the driver side kick panel under the fuse box. the charging circuit relay is a gray 4 pin C shaped conection. Believe it is the the bottom right relay out of the 4 available spots. Hope this helps.
Chicken12
Oct 14, 2015 03:54 PM
bradahman
Oct 1, 2015 09:24 AM
beltcutter
Sep 30, 2015 06:14 AM
JPV
Sep 28, 2015 03:15 PM
charlie_fong
Sep 27, 2015 10:06 PM
