Carburetor woes
Old Feb 10, 2009 | 03:47 PM
algranger's Avatar
Carburetor woes
Still battling my 22r carb.
It will start and run with starter fluid. The only time it runs on it's own is at higher rpms (2000+) and even then it stutters and chokes.
I know for a fact it's the carburetor
I've rebuilt and tuned/re-adjusted the carb.
Everything else in the fuel sytem is in check
Any ideas?
Old Feb 10, 2009 | 05:41 PM
XtraSlow_XtraCab's Avatar
Have you checked for vacuum leaks? Those symptoms sound very familiar to a vacuum leak. Also, I dunno if I posted the diagram for you... but I have an 85 vacuum diagram (federal) floating around one of the most recent threads.
How about the fuel pump? You'd think she wouldn't run at all with a bad one... but maybe there's a pinhole leak in the diaphragm or something.
Also, supposin you're choke works, perhaps the choke pull-off diaphragm is bad and not kicking off the cold start procedure. This could over-richen your mixture and cause it to run crappy. I don't believe a choke pull-off diaphragm is included with carb rebuild kits. Its a sealed, brass-colored unit that runs sideways along the rear of the carburetor.
Or perhaps the valves are adjusted wrong? If the intake valves are out of adjustment the motor will get too much, or too little, gas.
But, if you're dead-sure its the carburetor...
then readjust the float. That's really the only thing you coulda done wrong that would make it run this crappy. Float adjustment is EVERYTHING.
Old Feb 10, 2009 | 09:53 PM
algranger's Avatar
i am 100% sure its the carburetor. i put the carb from my dd on and changed nothing else and it ran fine. with the other carb back on i adjusted the float and it didnt help BUT i noticed the fuel level was high after trying to start. i replaced that little valve with the spring right in the middle of the bowl (it was seized down) and blindly adjusted the float down a little (due to the high fuel level) now it runs. not good but it kinda runs so i'll fiddle around with it some more
thanks
Old Feb 10, 2009 | 09:59 PM
Plumbrbob's Avatar
i hate those stinkin stock carbs good luck al
the_supernerd
Oct 1, 2015 09:20 PM
potatopants
Sep 15, 2015 06:26 AM
utahman
Aug 23, 2015 02:04 PM
daddio
Aug 9, 2015 07:17 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
