buckin problem
Old Apr 15, 2010 | 03:29 PM
85 FF / medic's Avatar
buckin problem
I have an 85 4runner w/ 22RE 5spd. All the sudden it started bucking when I let off the gas in any gear but significantly more when using the tranny to slow down. Im lost. Pinion angle is fine. Clutch is 3 years old but has been normaly abused offroad. It is fine under acceleration. Any ideas?...... thanks
Brian
Old Apr 15, 2010 | 03:34 PM
bipolarandproud's Avatar
Knock sensor ?/ I will usually Show A Check engine light . That's something to check out I guess.
Old Apr 15, 2010 | 06:11 PM
No check engine light....yet
Old Apr 16, 2010 | 11:13 AM
Aenema's Avatar
My 85 pickup did a similar thing, except it started at about 2400 RPM in each gear up until about 4th or 5th.. My check engine light has been on since i bought the truck 2 years ago and this has only occured maybe 2 or 3 times.
Old Apr 17, 2010 | 04:34 AM
Well it didnt do it at all on the way home from work....So im guessing the detroit was bound up.
Thanks
Old Apr 28, 2010 | 06:06 AM
OK it started again on the 3 hour ride home from Uharrie this weekend. The motor does not surge or sputter so it does not seem fuel or spark is the problem and it only does it when the clutch is engaged in gear with no throtle. It has to be in the drivetrain somewhere ..... right?
SubiKing
Aug 21, 2021 03:57 AM
theking11863
Mar 19, 2016 09:36 PM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
