Brake upgrade question
Old Jun 15, 2009 | 10:13 AM
forwardtocharis's Avatar
I was so close being done with a knuckle rebuild/rear disc brake swap and front disk upgrade when I discovered I purchased the wrong rotors for the front.
I now believe I need the front rotors from an FJ60 (Also called a land cruiser? Not so failure with the FJ-series)
If this is correct, is this the rotor I need:
Kragen / O'Reilly Part # 9838RGS
Raybestos Aimco-GS Brake Rotor
Any helps would be greatly appreciated.
Old Jun 15, 2009 | 12:21 PM
DeathCougar's Avatar
Yes, you need FJ-60 brake rotors, and V6 toyota truck calipers
Old Jun 15, 2009 | 02:03 PM
I have calipers from a 94 4runner with the v6, those should work fine, right?
Old Jun 15, 2009 | 05:23 PM
yes, those will work great. In fact, those are the better design with the wider anti-rattle spring
Jun 1, 2021 01:51 PM
rondogracing
Jul 14, 2015 07:00 PM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
