Brake Line?
Old May 27, 2008 | 11:23 PM
nor*cal's Avatar
Brake Line?
I was looking at buying a 85 SR5.
Somebody Stole the thing and took the master/Booster and cut the hardlines what I want to know is how hard i it going to be to replace them?
Thanks
Old May 28, 2008 | 07:04 AM
Elvota's Avatar
I have had really good luck finding hard lines at the salvage yard. You might even be able to find some on another Toyota that would work, if none of your particular model or year are available.
Old May 28, 2008 | 07:12 AM
dirtoyboy's Avatar
Its very easy....I would recommend buying new hardlines from the dealer....they arent that expensive....just screw the new ones in...attach the lines and bleed
Old May 28, 2008 | 08:02 AM
Belize Off Road Team's Avatar
Just replaced mine without taking anything off and it is a BIG pain. and i used copper beause it is easy to bend and the only thing available here.
Old May 28, 2008 | 08:20 AM
HAVOC's Avatar
Copper for brake lines is a big
Use steel, or don't use anything.
Old May 31, 2008 | 10:48 AM
anotherjeff's Avatar
nor*cal,
If you're in norte country, try Pick-n-Pull!
Fill out your profile! "norcal" means different things to different folks.
Old May 31, 2008 | 05:55 PM
slacker's Avatar
yes .. copper is not a good plan, way to soft , and not DOT .. it'll split just when you need them
any jobber or aftermarket parts supplier will have universal lines (metric) you can bend quite easly .. a socket or jar/round object makes a very easy and "profesional" bend , you dont need special tools .. just time .
Sep 4, 2015 09:27 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
CanRunner
Jul 20, 2015 01:29 PM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
