bad ignitor?
Old Dec 20, 2006 | 02:26 PM
OBX Fisherman's Avatar
bad ignitor?
I've got a 22R in an 85 truck that won't start. I believe the cause to be no spark because when I spray either into the carb it won't fire up. The signal generator is showing 156 ohms which looks to be within specs. The primary resistance on the igniter is .6 ohms. My Haynes book says that should be .4 to .5. The secondary resistance is 8.96K ohms and is within the specs of 8.5 to 11.5K ohms. Could the .1 over of resistance of the primary mean the igniter is bad?
This engine was running fine until I degunked it... I checked the dizzy and all electrical connectors for moisture and they all look fine.
Thanks
Gary
Old Dec 20, 2006 | 07:31 PM
reggie 00's Avatar
http://www.pirate4x4.com/forum/showthread.php?t=179253
Only real info i have came across about ignitors. The one in my 83 went south a while back and i stumbled onto this a few months a go and saved it for the next time.
Good Luck
Old Dec 21, 2006 | 06:16 AM
Thanks for link, I may try go this route!
Old Dec 21, 2006 | 01:35 PM
Th3duke's Avatar
Stupid question; you're not getting any spark at all? is it at least getting to the distributor?
Old Dec 21, 2006 | 02:15 PM
rdharper's Avatar
On your question about 0.1ohms over... its ok. Within measurement accuracy of your DVM.
Old Dec 24, 2006 | 06:45 PM
I was getting spark from the coil to #1 cylinder, but not to the rest. I replaced the plugs and wires and she runs fine now. Never heard of wires going bad overnight like this. Weird.
ghostmoney
Jan 28, 2018 11:42 AM
Blamalam
Aug 16, 2015 12:29 PM
corey519
Aug 12, 2015 11:12 AM
nonstop
7
Aug 11, 2015 09:26 AM
keithporter83
Jul 18, 2015 12:37 PM
