axle question
Old Oct 19, 2009 | 01:02 PM
MurphyzRunner's Avatar
axle question
I have a 85 4runner with a 93 rear axle with a lockrite, This may be a dumb question but can I put my rear 93 axle third member up front and my front in the rear axle??? reason why is I want my lockrite up front and buy a spool for the rear.
Old Oct 19, 2009 | 01:25 PM
TOYOTA 1's Avatar
yes you can.
Old Oct 19, 2009 | 02:01 PM
AZkid's Avatar
they're both 8 inch diffs you silly head!
Old Oct 20, 2009 | 07:34 AM
Ya, I thought so.... anyways just checking someone told me that the newer axle out of the 93 truck was "heavy duty" because of the V-6 engine so that's why the dumb question.
Old Oct 20, 2009 | 08:09 AM
desertcamper67's Avatar
I've always assumed that you had to use another 4 cyl diff. Are their any internal parts that are different between V-6 and 4cyl? How about the fit? Is there any grinding needed to be done to the housing opening to make it fit?
Old Oct 20, 2009 | 10:51 AM
Etype R's Avatar
You can use a V6 diff on the front solid axle, it will bolt right up. The diff housings are different, as are the bearings for the V6 carrier. It is a stronger design, and some guys run them front and back.
oldirtydirt
Feb 23, 2020 09:30 AM
polo451
13
Nov 20, 2016 07:49 PM
jerusry
Oct 19, 2015 05:28 PM
delmert
Sep 30, 2015 04:34 PM
deepmarsh
Aug 6, 2015 03:44 AM
