Ac comp replace Q's?
Old Apr 27, 2013 | 07:26 AM
ojm3's Avatar
Hey guys I'm about to replace the compressor on my 84 with another compressor from an 84 in very good condition. My question is after I disconnect the compressor and all the freon leaks out. After I hook everything back up can i simply just change the oil and put in the retrofit conversion with the compressor? Or do I need a vaccum since it leaked out?
Old Apr 27, 2013 | 12:18 PM
slow-mo's Avatar
Yes, you'll need to obtain a vacuum in the system as this will remove nearly most of the moisture in the system. The small traces of moisture that is left will be handled by the receiver/dryer component.
Since you state regarding doing a conversion, I'll will state that releasing R-12 into the atmosphere is illegal. Your supposed to capture the refrigerant to be recycled.
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
rushw
Jul 18, 2015 01:46 PM
1994toyota
Jul 17, 2015 03:03 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
