90 pickup stuttering
Old Oct 7, 2021 | 12:15 PM
rphoward's Avatar
I'm back! Long time since I've been on this forum....
My 90 (22re) pickup has been running poorly. It began suddenly and I barely made it home after picking up a table saw. Idles "OK," but when opening the throttle it stutters and backfires; complete lack of power and it is not driveable
So far...
- New plugs, wires, cap and rotor
- Timing verified
- Replaced fuel filter
- The battery came loose (bungee broke), the connectors were loose, and I replaced it as it was bad. I was hopeful, but that didn't solve the problem.
- Replaced the fuel injectors before all this, have maybe 200 miles on them.
- I checked for vacuum leaks, found one but fixing it didn't change anything.
I built the rig from the frame 16 years ago. Some possibly relevant upgrades:
- Header and flowmaster muffler
- Emissions removed and blocked off.
- Dual row timing chain and "upgraded" water and oil pumps
- LCE stage 1 that included larger throttle body
- Engnbldr cam
- MSD ignition module and coil
What should I look at next? Alternator, ignition coil? I'm tired of chasing this around, and I'm officially ready to ask for help.
Thanks!
Ridge
Old Oct 7, 2021 | 12:32 PM
dbittle's Avatar
So far...
- Timing verified
- Engnbldr cam
Thanks!
Ridge
Two things that immediately spring to mind are fuel pump and throttle position sensor. You have a timing chain, so check it didn't jump time.
NotSoNew92
Apr 23, 2017 03:28 PM
Offcamber1
Mar 2, 2014 05:41 AM
KemalPamuk
Jan 10, 2014 08:50 PM
calisurferdude2000
Oct 4, 2009 04:14 PM
Firsick
14
Feb 20, 2003 06:36 PM
