85 4runner EFI Hesitation
Old Feb 25, 2010 | 05:48 PM
mhowardcda's Avatar
Hello
About 2 months ago I changed the clutch in my 4runner (276,500 miles). Soon after the clutch was changed I began to notice that while driving on level road or down hill and trying to maintain throttle speed I get a hesitation or jerking. I cannot make it hesitate in neutral it only happens while in gear while trying to maintain a constant speed.
I have already checked the drive line and the egr valve. I have looked for a vacuum line that may be disconnected or damaged. No luck so far.
Any ideas?
Old Feb 25, 2010 | 07:17 PM
myyota's Avatar
When was the last time you replaced the fuel filter ?, I would start there first, the second thing i would check is the TPS, if its original they can go bad and cause driving issues like your having, so check it and see if its properly adjusted, or possibly bad.
Old Feb 25, 2010 | 07:31 PM
laskt9's Avatar
im gonna second the tps. it could be a dead spot on it. if i vac line was disconnected you would have a raised idle. when was the last time you did a tune up?
Old Mar 5, 2010 | 11:59 AM
SanDogDewey's Avatar
Originally Posted by mhowardcda
Hello
I have the same symptoms on my 85 pickup with R22, so I don't have the TPS. Any other ideas?
BeMiceElf
Oct 10, 2015 09:40 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Sandman
Jul 14, 2015 12:36 PM
dpridgeon3
Jul 9, 2015 01:18 PM
colinmil
Jul 6, 2015 04:03 PM
