'84 2wd pickup, hole of some sorts in tranny?
Old Mar 12, 2016 | 11:44 AM
jrob4206's Avatar
Alright so I decided to track down a leak that has been going on today and when I got under the truck I noticed this small rectangular hole. I'm not sure if it's always been there or suppose to. Any feedback would be great. I can get more pictures if the 1 is not good enough.
Attached Thumbnails '84 2wd pickup, hole of some sorts in tranny?-20160312_123931.jpg
Old Mar 12, 2016 | 01:18 PM
CamTom12's Avatar
Pretty sure that's to allow stuff to vent/drip out or your bellhousing. No fluids are supposed to be in there, so if you're getting fluid leaking out I'd suspect a front seal on the transmission.
Old Mar 12, 2016 | 05:23 PM
22R88's Avatar
Try to determine it the stuff is Gear lube (distinct smell) oil or coolant. Look close up from there at the EGR crossover plate bolts and also the valve cover rear half moon rubber seals. I just went through something like this and the EGR bolts hold a plate that has coolant and exhaust gas behind it but the bolt threads if loose tie into the oil passage in the head and can drip oil....but look good at valve cover and half moons first. If gear lube the front trans seal is bad as stated in earlier post. and I do think the hole is a weep hole so if it is not wet in there it may well be the VC or EGR plate
Old Mar 13, 2016 | 04:00 PM
stioc's Avatar
Yep, that's a weep hole in the bell housing. The oil is probably just the engine oil leaking from the rear main seal but definitely check the type of oil it is and if you're low on the engine oil or trans oil.
Old Mar 13, 2016 | 05:00 PM
22R88's Avatar
Weep hole looks dry in the photo ????? If it is also look at the oil pan gasket the area up there looks wet ??? Any more pics ?
22R88
Up&Down
10
Apr 5, 2016 09:36 AM
fine69
Mar 16, 2016 05:48 AM
d-wood
Mar 11, 2016 07:05 AM
FinallyOffRoad
Mar 10, 2016 12:16 PM
ZRTALPHA1
Feb 21, 2016 12:12 PM
