32/36 backfires when coasting down hill
Old Apr 1, 2012 | 11:19 AM
Challenger's Avatar
I just put a rebuilt weber 32/36 on my 85' 22r 2wd and it runs fine except when i'm coasting down a hill then it makes popping backfiring sounds. I checked the timing and its good and the carb is set correct. Any ideas?
Old Apr 1, 2012 | 04:18 PM
rokblok's Avatar
Generally speaking, backfiring on deceleration is caused by excess fuel(too rich), that is in the exhaust after combustion, igniting. So lean it out a bit and try that.
Backfiring on accel or steady throttle can be timing or to lean. To lean causes the fuel to ignite easier and faster, and the intake port/manifold will get hot spots igniting the fuel before the spark plug can do it. This is my experience anyway...
Old Apr 2, 2012 | 02:15 PM
Challenger's Avatar
I leaned it down and no more backfiring. Thanks.
Old Apr 2, 2012 | 04:40 PM
rokblok's Avatar
You're welcome. Glad it helped.
Pri$erulz
Nov 17, 2019 08:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
kbpickens
Oct 2, 2015 03:37 PM
kawazx636
Sep 29, 2015 08:22 AM
skouba
Sep 14, 2015 06:58 AM
