22RE check engine light, running way too rich
Old Jan 4, 2010 | 08:33 AM
1st_gen_runner's Avatar
I have a 1985 4Runner SR5 with 22RE and 5 speed manual. Last week i got the emissions tested and it failed. The CO levels are too high meaning it ran way too rich. What happens is when the motor runs at close to the same RPM for a certain amount of time, the check engine light will come on and it will go into open-loop. It will burn a lot of gas and run too rich, and that's why it failed. Every shop I called said something different and they all want about a $100 diagnostic fee just to see what's wrong. Some shops say it was the O2 sensor, the cat, or the spark plug wires.
Any input?
Old Jan 8, 2010 | 06:17 PM
TORTIS's Avatar
You can check the O2 sensor , and plug wires with an ohm/voltmeter. check the MAF
Old Jan 8, 2010 | 08:33 PM
myyota's Avatar
If your truck has the original cat and 02 sensor, then you should replace both. I would start by replacing the 02 sensor first, thats what the computer uses to moniter the air fuel ratio, and if its bad it could be sending the wrong readings to the computer causing the engine to run rich.
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
94hiluxZE
Jun 22, 2015 10:42 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
Dr. Evil
Jun 7, 2002 09:19 AM
