22r power mods?
Old Apr 16, 2007 | 08:30 PM
simplypv's Avatar
dude, you are a wealth of information! i'm doing alot of reseach atm while i build up my bank, then i'll tackle the carb, tranny(seals), clutch and exhuast leak at one time. after that i'm going to revaluate where im at powerwise and if im still not happy, start researching very heavily in regards to the stage 1 camshaft kit and master rebuild kits. so bear with me and my (dumb) questions. lol.
as for the carbs, which one is better? the 32/36 or the 38/38?
Old Apr 16, 2007 | 08:33 PM
Hayes's Avatar
you could always convert to propane if you want more power...I HEAR...don't know first hand...that they are pretty powerful, compared to stock 22R's.
Old Apr 16, 2007 | 08:47 PM
simplypv's Avatar
hahah, im sure the amount of $$ for a propane conversion kit would exceed what it would cost to get a reasonable amount of power via aftermarket parts.
Old Apr 16, 2007 | 09:17 PM
bktaco's Avatar
i dont know, i've already put a grand into mine
http://www.gotpropane.com/p4.html
i really have not seen this before, dont have any idea of performance.
Old Apr 17, 2007 | 07:36 AM
  #25
4Rocker's Avatar
Neither is really 'better' than the other, they just have different uses. The 32/36 is a good stock replacement or mild mods carburetor. From what I hear, it gets pretty decent gas mileage with an increase in power over stock. The 38/38 is typically used in engines that can support a higher flow rate, which is why this carb is good on engines that have aggressive cams, ported heads, OS valves, and a free flowing exhaust. The 38 is also the carb that comes with the LCE supercharger kit. From my experiences with the 38, it makes good power, but dont expect anything good for gas mileage, I get about the same as my friends Yukon with a 350.
For your engine I would probably recommend the 32/36 unless you have some head work done to allow better flow at higher rpms.
Old Apr 20, 2007 | 05:52 PM
  #26
mudtoy's Avatar
I'm now putting a Comp Cam in my 85 p'up with 22r, getting it back together now, cant wait to see what it'll do. I got a mild cam part # 87-123-4. Nothing else has to be altered to do that. Was going in to do valve seals and the next I know, wellllll, I'll put a cam in it while im in there, ya know how that goes! Let ya know in a couple days how it does.
Old May 13, 2007 | 07:17 PM
  #27
mudtoy's Avatar
Just put a mild comp cam in on my 85 22r and seen a good increase in power at higher rpm. Got a hooker header going to be installed this week with a high flow cat. With running 33 thornbirds, everybit can help me get out of third gear up hills!
Old Jan 9, 2008 | 10:27 PM
  #28
84 yota ex-cab's Avatar
I got a 89 toyota 4x4 std. cab with new 22re. It doesnt have much power and only gets about 17-18 mpg. Any suggestions on what could be the problem? any mods to gain power?
Old Jan 10, 2008 | 05:26 AM
  #29
Hayes's Avatar
Have you done general maintainance? plugs wires timing...
Old Jan 10, 2008 | 01:41 PM
  #30
Trustyrusty's Avatar
Some guy who once acted like he knew what he was talking about said the SEARCH BUTTON!!! will give you 50 horsepower...
Old Jan 10, 2008 | 03:54 PM
  #31
bigarms23's Avatar
do a simple efi conversion
Old Jan 11, 2008 | 01:50 PM
  #32
Yes it is all tuned up. My timing is on 5 degrees with the check connector shorted but i was thinking about advancing it. Would this do anything as far as power or gas milage?
Old Jan 11, 2008 | 03:36 PM
  #33
elvis's Avatar
Originally Posted by Hayes
I would get springs, retainers, look at lifters...but then again when I rebuild my engine I want it to perform well and not have to worry about it.
Why? You revvin it to 10 Grand? Stock springs are fine.
http://www.engnbldr.com/Toyota-Hotlicks.htm
A tad noisy but the price is right..
Old Jan 11, 2008 | 06:37 PM
  #34
Hayes's Avatar
A cam usually adds stress to the springs, I will upgrade mine for peace of mind.
Old Jan 11, 2008 | 06:45 PM
  #35
TrikeKid's Avatar
ok, so the cam gear is utterly useless for me then? i wonder what is causing the gutlessness then. a friend of mine has an 84 that is completely stock and it pulls along decently... mine struggles to take off.
He has stock gears, with stock sized tires. If you re-gear (4:88 will make for the same gearing as stock with 33" tires) you will pick up a big performance gain. You probably won't be as quick as your friends, due to the large rotational weight of the bigger tires, but it helps a ton. I went from 3:90's (PO grenaded the rear diff, and grabbed one out of an earlier truck)to 4:88's and it's night and day.
Old Jan 13, 2008 | 08:33 PM
  #36
AustinTaco's Avatar
This is pretty good info. I am trying to determine which carb is on my 4runner and I found this online:
http://www.redlineweber.com/html/app..._choice_32.htm
keithporter83
Jul 24, 2015 07:37 AM
Massmayhem247
Jul 18, 2015 05:46 AM
cars-guy
Jul 11, 2015 07:51 PM
icentropy
Jul 11, 2015 07:21 AM
Nickdigg
Jul 7, 2015 06:04 AM
