22r heating up
Old Dec 21, 2009 | 02:44 PM
wannagetrdone's Avatar
Exclamation 22r heating up
I have an 85 sr5 4x4 ext cab. I recently just swapped a 22re out of an 89 in its place by converting it to carb. This engine has got hot ever since I put it in the truck. I have replaced the thermostat ran it without one replaced the water pump and even flushed the radiator. I dont know where else to look.
Symptoms are as follows.
-temp slowly climbs to normal position
-temp rises slightly above normal then drops back to normal(I think thermostat opening)
-from normal the temp will start to climb slowly til it gets hot
-will not heat up just idling but if i crack the rpms a little(2000) or so it will heat up
I have never let it get over the top part of the line in the normal mark Just wondering what degree this is and how hot can they get before I really hurt it.
Old Dec 21, 2009 | 05:58 PM
Guys any imput would be a big help and much appreciated
Old Dec 30, 2009 | 10:20 AM
84Horunner's Avatar
http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
Hope this helps.
Old Dec 30, 2009 | 12:05 PM
Travisfab's Avatar
replace the radiator
Old Jan 8, 2010 | 06:22 PM
TORTIS's Avatar
Did you burp the system?
buckz6319
Aug 5, 2017 03:50 AM
alexcarey
Oct 14, 2015 06:05 PM
Matthew Perez
Sep 28, 2015 05:43 PM
taraf
Sep 25, 2015 02:57 PM
87runner_
Sep 19, 2015 03:28 AM
