20/22RTE Hybrid
Old May 7, 2010 | 01:10 PM
Airo Spade's Avatar
20/22RTE Hybrid
Hey new here but looking for help. Im planning on making this as difficult as possible for myself but what did I miss here for an engine rebuild and looking for lots of help
$100 Air Flow Sensor 1982 Supra 5M-GE car-parts.com MAF AFM same thing
Read up on it. Its just like the throttle body the MAF on the supra is 2.5x2 and the stock 22R is 2x2. For this mod it is a direct bolt on but you must get the right year. Or your going to have to swap out the guts
How to
http://www.pirate4x4.com/forum/showthread.php?t=594281
http://www.celica-gts.com/resources/efi_intake.html
https://www.yotatech.com/forums/f180...m-22re-136442/
$40 TB 5M-GE from car-parts.com
Reason for the switch better throttle response and possible HP gains in the higher rps. Also the throttle body on the 22RE is 55mm and the 5M has a 60mm.
How to
www.celica-gts.com/forums/index.php?topic=7543.0
www.22rte-trucks.com/simplemachinesforum/index.php?topic=1053.0
$25-40 Post 89 Intake manifold car-parts.com
This is the only info I have found and for 25 bucks why not if its a good swap. It basicly says i dont have to take a grinder to it. go down half way to the plenum aka intake manifold
$320 RC Engineering fuel injectors www.rceng.com
So Im not sure what type to get peak and hold or saturated. Im thinking of getting peak and hold at around 400-500cc my goal is to get 250-300hp out of this engine with the turbo without Im looking for around 200hp so I need help with which injectors to get?
Link helpful for cross refrence and just lots of info
http://www.antikmachine.com/dwld/injectors2.pdf
Fuel Rail, Fuel pump and Fuel regulator???
I havent found much info on this just that from my experience which is vary little and my boss that worked on 67 chevs off the line mumbling random stuff. That most fuel pumps back then had 60psi but at high rpms there is no vacuum to run the fuel pump so the amount of fuel you are getting to your injectors after the regulator is 13 when the minimum should be at least 15. Thats all I know not sure if its right. So tips and pointers for this.
If I missed anything other then tubing/ cac aka intercooler or the west gate let me know.
Next up on the list Ignition Not in order
Spark Plugs/boots Not a clue. Hopefully simple
Custom Plug wire bracket www.mr-gasket.com/ProductDetails.aspx?modelNumber=6018&productID=170 &majID=550&minID=0&selection=17&minselection=3
Its just so damn pritty
$165 MSD 6200 6A on ebay but its www.msdignition.com/info.aspx?taxid=4&taxid2=94 for info and specs
I saw that
$27 MSD 8910eif found on ebay but its www.shopatron.com/products/productdetail/part_number=8910EIS/424.0.1.1
Its for the proper fuel spray when using there ignition control
Do i really need these 2 parts are there better worse not sure at all
Distributor do i need to replace it?
And finally for this part I know I missed something is the ECU should i use Magasquirt or something else
working on the HEAD now
$50-$100 20R Head car-parts.com
My plans where simple when i started out make a hybrid and be done. After reading found out your not supposed to use the hybrid with efi and then I decided to turbo on top of this Ill find out vary soon if there is any advantages to doing this. I will have to do alot of porting grinding drinking and milling to get this to work.
Useful tips for the hybrid are everywhere what Im doing not so much
http://www.celica-gts.com/users/oldmage/20RE-1.htm
start here and just read until you have more info about it then you know what to do with
www.google.com/#hl=en&source=hp&q=22re+hybrid&btnG=Google+Search& aq=f&aqi=&aql=&oq=22re+hybrid&gs_rfai=&fp=75855d28 3b36db78
$400 LE rocker arm set http://www.toyotacatalog.net/M1WebGe...9-7A46D7654833
Stock 20R and 22R have an oil distribution problem here and with turbo and cam shaft Im going to guess this is a good investment correct me if Im wrong.
$185 DOA cam Shaft c270 http://www.doaracingengines.com/page1/page1.html
I read alot if you havent noticed and this cam shaft from what I have read is what everyone usually ends up getting. So I'm going to start here and go from there
$100 Adjustable Cam Gear http://www.toyotacatalog.net/M1WebGe...6-041B176581DB
Its for fine tuning your Cam timing Im going to say critical for a good tune.
$200 20R/22R/RE Pro Camshaft Kit w/Chromoly Retainers www.toyotacatalog.net/M1WebGear/ProductDetails.aspx?PartUniqueID=ABCDF6FE-B701-4857-935B-E5A8E0523340
Need better then stock springs with turbo thats all I got
$240 Valve's and valve seat's http://www.toyotacatalog.net/M1WebGe...ss=1669&Page=1
Im going to guess that I can find cheaper but i need direction also 20R valves or 22RE valves
Metal Head Gasket not sure where to go
$126 ARP Head stud kit http://www.euroexportinc.com/product...350&language=1
this goes with the metal head gasket/ turbo stock lb torq 55 these I believe 115lb cant find link
$60+ gasket complete gasket set http://www.google.com/products?q=22r...et+&hl=en&aq=f
Remember to get quality gaskets from people you trust
$150 Timing chain Kit LE http://www.toyotacatalog.net/M1WebGe...4-69F9E446E60D
You have to get this or your engine will die thats it well around 130k but thats it
Now down to the block
$20 complete stock engine with ok extra goodies cylinders 2 and 4 leak. Thinks its the valves but doesnt know said was never over heated but god only knows
$250 2 complete engines a 22RE and a 22RTE comes with complete turbo setup all stock and extra goodies.
$350 20R/22R/RE Pro Chromoly H-Beam Connecting Rod Set http://www.toyotacatalog.net/M1WebGe...5-8C521139767F
I want it but is it actually worth getting can I go cheap and if so what.
$600 Pistons http://www.toyotacatalog.net/M1WebGe...px?Class=14671
What do i get instead of this or should i get these
VARY usefull links
http://www.toysport.com/technical%20...tech_notes.htm
http://www.4x4wire.com/toyota/faq/parts/
http://lakebox.dnsalias.com/photos/1...0Injection.htm
www.google.com
Old Aug 8, 2010 | 12:50 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Bump...
How you gonna get an intake on it again?
Old Aug 19, 2010 | 04:04 PM
XtraSlow_XtraCab's Avatar
Shoot man...
I'm all about outside-the-box ideas... but for the total of that price list you could just drop in one of them Toyota V8 motors. Way better of a platform for performance.
Old Aug 19, 2010 | 04:16 PM
xxxtreme22r's Avatar
or drop the cash for a SC'd LCE engine. a hybrid motor I would do using not much more than junk yard parts and a standard cost of a rebuild.
Jun 1, 2021 01:51 PM
bamachem
Apr 3, 2006 07:31 AM
RebuiltRunner
Jul 15, 2003 02:29 PM
