1986 Toyota 4 runner with 4.10's
Old Sep 18, 2007 | 05:36 PM
1986Yotaboy's Avatar
Question 1986 Toyota 4 runner with 4.10's
Is a 1987 toyota 4 runner and a 22re that has a inchworm dual case, and 4.10s gear under powered? Its also locked in the rear. I need to get good freeway speeds, and will it do it?
Old Sep 18, 2007 | 09:02 PM
simplypv's Avatar
all comes down to what size tires you are running and the gear set used.
Old Sep 18, 2007 | 09:18 PM
slus's Avatar
My magic tire size guessing 8 ball says....
If you are running dual cases and are locked, I assume you're over 33s. 33 inch tires is about the limit for decent on road manners with 4.10s imo.
Old Sep 18, 2007 | 10:18 PM
XtraSlow_XtraCab's Avatar
I agree... the smartest thing to do would be a rear end swap if you go 35's. The little 4 cylinders can only handle so much on there own... tough little things.
vasinvictor
Jan 20, 2016 12:39 PM
DacodaYota
Sep 2, 2015 02:13 PM
P51warrior
Jun 25, 2015 05:50 AM
NerfHerder-97SR5-
Jun 17, 2002 05:31 PM
