1985 p/u aisin clutch cyl part #'s???
Old Feb 26, 2017 | 12:19 PM
colorado85pu's Avatar
Question 1985 p/u aisin clutch cyl part #'s???
I've been searching all over and keep coming up with different part #'s for master and slave clutch cylinders.
can anyone help?
so far I have :
master
W0133-1628265
8116-05255616
31410-35142
ASCCMT003 / CMT003
CMT-011
TDT-MC-1
slave
W0133-1631388
W0133-1630185 (diesel?)
8116-05255641
31470-35100
31470-35041
31470-22150 / CRT-017
ASCCRT001 / CRT001
CRT-004
my truck is an '85 reg cab 22re 5-sp 4x4
JT4RN60S1F5038653
Old Feb 27, 2017 | 10:07 AM
Co_94_PU's Avatar
Might get more help if you said what you're doing and why..
Best source is going to be the dealership parts counter person. Have all the VIN data handy including build date transmission and gearing..
Old Feb 27, 2017 | 10:53 AM
just trying to replace my clutch cylinders with aisin oem stuff... it's an '85 5-sp; have had trouble deciphering VIN, but best I can tell it's an sr5 with w56 tranny
Old Feb 27, 2017 | 12:03 PM
Co_94_PU's Avatar
crt-001 and cmt-003, are the Aisin world Corp parts..
Best bang for your buck long term is the rehabilitate what you have with fresh seal kits. This leaves you with the original castings from back when Japanese manufacturing was unbeatable..
Old Feb 27, 2017 | 12:14 PM
wyoming9's Avatar
Red face
You must have far better luck then me most times the piston and bore are so pitted that till it was cleaned up even oversize o rings will no longer seal
These ones I get might still have the original fluid and lots of water 20 plus years with the same fluid will do in most hydraulics
I must say Aisin Aftermarket is great for looking up part numbers
Old Feb 28, 2017 | 08:02 AM
thefishguy77's Avatar
I did Aisin on my last 2 toyotas and ordered them of amazon. Paid something like $60 for both delivered. If it's an original transmission on an 85 22re it should be a W56
Old Feb 28, 2017 | 08:57 AM
old87yota's Avatar
Well... if clutch hydraulics are anything like my brake master cylinder, you will have some pitting. I would not want to reuse my old brake master cylinder because the pits would chew up the new seals and I would probably have to bore out the cylinder quite a bit for a true, smooth surface.
I bought a new Aisin brake master cylinder as a replacement and I am pretty sure they used the same casting. You can see where they ground down the word "TOYOTA" to make it an "aftermarket version".
So far, it seems to be an exact replacement, way better than the parts store replacements.
I would think their clutch hydraulics would be the same.
To the OP: I don't know which part numbers are correct, but different vendors do list things under their own part numbers, which makes things confusing.
