1985 22r timing
Old Sep 14, 2022 | 06:39 PM
1985connor's Avatar
1985 22r timing
Hey everyone, I’ve been trying to time my 1985 pickup with a 22r. I just replaced the vacuum advance unit. When I unplug the hoses and plug them, I set it to 0 BTDC. When I plug the hoses back in I get no advancement at all. Aren’t I supposed to get an advancement to around 5-7 with the hoses plugged in?
Old Sep 15, 2022 | 12:30 PM
2ToyGuy's Avatar
If the idle speed is set correctly (750 RPM), no, the timing should be 0°. It will only advance as the engine speed increases,
There's the entry from the FSM.
Edit: I apologize. All that stuff above is with the vacuum lines, both of them, disconnected and plugged. With the vacuum lines on, it should be 12-15° BTDC at idle. MAX of 950 RPM, correct is 750 RPM. At Idle, fully warmed.
My sincerest apologies.
Does that help any?
Pat☺
Last edited by 2ToyGuy; Sep 15, 2022 at 02:19 PM. Reason: Correcting misinformation.
Old Sep 19, 2022 | 07:58 PM
1985connor's Avatar
Does that help any?
Pat☺
I have the Rpms set at about 800. The inner line has vacuum and the out does not unless it is given throttle. I have set the timing at zero with both of these hoses plugged. When I plug in the inner line, there is no change. There is also a new vacuum advance just installed that holds its vacuum well.
Levi_Tim
Sep 16, 2017 06:12 PM
