1984 Toyota Problems
Old Oct 20, 2006 | 05:10 PM
thrsdy1203's Avatar
I have a 1984 Toyota 2wd with a 20r carb motor.
I am unsure exactly what the problem is with it but i am guess it is a bad headgasket as there is coolant in the oil although what throws me off is the fact there is oil dripping out of the valve cover gasket.
So could a bad valve cover gasket cause these problems...the truck runs and drives however after being warmed up it will die/stall at an idle state meaning you gotta keep the foot on the gas to keep it running. I have not yet had it completly overheat on me at all and there is also no steam coming from the exhaust nor have i seen the temp guage go on red.
if you guys could please help me diagnose the problem i would really appreciate it..Just ask me questions and i will answer them to the best of my knowledge so we can together figure out what is going with the vehicle.
Hopefully then i can figure out how to fix it and if it isnt the headgasket that will be awsome but the coolant in oil is really freakin me out.
truck has 130k.
Ryan
Ryan325es@gmail.com
85run
Jul 8, 2015 11:20 PM
Jnkml
Jul 6, 2015 01:20 PM
Falcon78
Engine Swaps
Jul 1, 2015 05:01 PM
Outsane
Jun 24, 2015 05:52 PM
