1" Body lift and new bushings, OK???
Old Jul 9, 2007 | 02:30 PM
Richredneck989's Avatar
Based on the fact that we are replacing a section of floor, both sides, and it is under the rear seat where the body and frame are VERY close I am considering a 1" body lift as well as new Energy Suspension bushings. I am not a big fan fo BL but if I can find a 1/2" or 1" set of spacers I thinks it will be OK.
So any thoughts on the Energy Suspension Bushings? good, ok, bad? better stuff out there?
How about a sourcce for a 1" BL? not any higher though.
As always thanks to all of those that have helped us out from this board, you rock.
Old Jul 9, 2007 | 03:50 PM
navyredneck's Avatar
The easiest way to do it is to order the lift blocks, hardware, and body mounts from 4crawler:
http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml
I did the same for my 3" lifted pickup truck because the old kit was falling apart and I wanted to redo the mounts.
From what I could read before, basically all poly body mounts are pretty much equal. I even started a survey to see if anyone could tell me differently.
A tip: start spraying all the bolts NOW with PB blaster. It took several weeks of spraying to get some of mine loose. In fact, while 80% came loose, I had to drill and cut the rest off. I'm still waiting to borrow a friend's impact wrench to get the bed bolts off.
Old Jul 9, 2007 | 05:09 PM
waskillywabbit's Avatar
I do 1" body lifts (all metric hardware) and can get the body mounts as well.
http://www.wabfab.org/products/bodylifts/bodylifts.htm
Let me know if you have any questions.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
upongame619
Aug 1, 2015 12:12 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
Cabell
Jul 24, 2015 12:14 PM
