Pre 84 Trucks 1st gen pickups
wires
Old Dec 12, 2007 | 05:17 PM
first gen. yota's Avatar
wires
my truck is a 79 pickup. there are a few wires going to the alternator. well i saw that the o2 sensor had no wire going to it so i tried to hook one of the wires to it cause it seemed to just be taped along with the others. i later found that my truck originaly had no o2 sensor but the exhost manifold was replace with one that did. so long story a little shorter i think i need to find where that wire i pulled out goes. so if anyone can help with a picture or diagram it would be appreciated. who knows maybe it doesn't go to anything.
Old Dec 12, 2007 | 07:56 PM
rowdy235's Avatar
its a 20r right. The 20R, in stock form, had no o2 sensor. Nor did it have the hookup. As for the alternator, is it working? If so, I probably wouldn't mess with it. If you want to "fix" it, I suggest you get a service manual with good wiring diagrams.
PS what color are the wires? I may be able to look them up for you.
Old Dec 12, 2007 | 09:13 PM
dropzone's Avatar
Fossilized
here is a PDF format of my 1981 FSM wiring diagram, it is for a 22R but it might help you figure it out...good luck with it, wiring gremlins are my nemisis!
http://www.portroels.com/lincoln/198...%20Diagram.pdf
Old Dec 13, 2007 | 02:02 PM
yea thanks guys. my alternator does work so maybe i'll just leave it.
80Truck
Oct 12, 2025 07:25 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
ToyoToler
Aug 8, 2015 08:43 AM
Daneums
Jul 28, 2015 11:57 AM
TDonkey
Jul 26, 2015 10:14 AM
