Pre 84 Trucks 1st gen pickups
window and door rubber
Old Dec 31, 2021 | 04:05 AM
yotaaddict's Avatar
Anyone know if there are any sources for window and door rubber/trim for pre 84 gen 1's???
Old Jan 2, 2022 | 02:15 PM
Punjab's Avatar
Occasionally you can find them new on eBay but that's about the only regular place that I see them listed.
Old Jan 8, 2022 | 05:03 PM
homeyclown's Avatar
I just installed this in my 83. Snipped a 45 in it on drivers side where it makes a 90 deg. Worked ok. Other side i just ran a pc straight up the side then butted the top pc to it. Worked much better. Is it correct....prob not. It looks better than the other side. Both sides bunch/crinkle once in one spot where it goes around the wing window. Not noticeable unless you stare right at it. Window works 10x better.
https://www.ebay.com/itm/165044122132
Old Jan 10, 2022 | 01:40 PM
FourEyes's Avatar
5 Year Member
These are a bit expensive but they are OEM:
https://parts.lakelandtoyota.com/sho...rimLevel=18363
Not sure if you have vent windows or not but I just looked at my receipt and the window rubber part number for trucks with vent windows is: 6814189106
Fit perfectly on my 83 with vent windows.
Speaking of vent windows here is the diagram and parts list for those seals as well:
As a side note, if your windows are sticking in the seals as you roll them up and down, spray some silicone spray in the seals. It really smooths it out. Also it helps with the seal installation!
Hope this helps,
Sam
deepsouth
Apr 3, 2014 11:36 PM
woodendude
Feb 14, 2009 03:38 AM
toyaholic
Jan 18, 2006 04:49 PM
Goose
Jan 23, 2004 05:34 PM
