Pre 84 Trucks 1st gen pickups
What Are These Wires For?
Old Apr 2, 2007 | 12:21 PM
Yota Tony's Avatar
Was working on my 82 Pick up a little bit this past Saturday and I found a few wires that had been snipped.
I'm hoping someone can tell me what the heck these are for? From there I can figure out how to go about hooking them up again.
Old Apr 2, 2007 | 05:49 PM
My814x4's Avatar
Those are fusible links that power the headlights, ad other electrical things on the truck. They hook up to the positive battery post . That is the green and red wires and the blue wire. I think the blue wire is not fusible link wire might ought to repl. that one.
Old Apr 2, 2007 | 06:25 PM
Yota Tony's Avatar
I'm also hearing they are for thermo sensors. I will poke around tomorrow and take more pics.
Old Apr 3, 2007 | 07:15 AM
jriebe's Avatar
I think there is only one fusible link in that bunch...the whitish one. some of those might be for emissions crap to.
Jon
Old Apr 3, 2007 | 07:49 AM
Yota Tony's Avatar
Canadian and Federal (I think) 82 4wd models really didn't have much in the way of emissions. I'm gonna look at it more tonight.
Old Apr 5, 2007 | 06:44 AM
4Rocker's Avatar
Those are NOT fuseable links. they are factory wiring connectors that connect the wiring harness to various sensors/emissions crap on the engine. Of the top of my head im not sure exactly which goes where, but on my 84 I am in the process of removing all of them after converting to a weber carb. Check sensors on that side of the engine such as your temp sensors and oil pressure sender to see if they are hooked up. Its not uncommon for the wires to shear off right by the connector as they get old.
Old Apr 5, 2007 | 09:36 AM
Yota Tony's Avatar
They snipped ones are not for emissions.
I know what they are for now and they are hooked up again.
Old May 4, 2007 | 02:07 PM
Island_Yota's Avatar
Im having the same problem with my wiring, bought the truck from a guy who tore it down to do the frame but never got around to it, so ive been peicing it back together and im stuck at the same wires. Theres also another white-ish colored one with a ring terminal on the end over on the drivers side that im not sure about.
Old May 4, 2007 | 02:33 PM
Yota Tony's Avatar
They go to the battery.
Old May 4, 2007 | 02:41 PM
All of them? I have some 16g fusable link aswell, the Haynes manual is just really confusing.. Maybe im just too dumb to read a wiring diagram . Il take some pics of my mess..
Old May 4, 2007 | 03:41 PM
Heres pics of the wires..
Green + red, missing connecter on gray wire? No idea on these
Yellow + Black, and another connector thats kinda melted but is usable, no idea on these.
In this pic im holding a peice of wire with a spade connecter, the previous owner put a tag on it that says "To block by fuel pump" Im thinking its connects to the black wire that runs along sidethe carb?
This one is over on the drivers side.. possible goes to the alternator? No idea really, its got some heat protective stuff on it and its black.
Old May 4, 2007 | 04:01 PM
1eye's Avatar
Wiring
If you want, I can scan the factory Wireing diagram and sent it to you/post it for you guys.
1eye
Old May 4, 2007 | 04:07 PM
1eye
That would be a big help, I cant seem to find one anywhere online.. I bought a haynes manual for the wiring diagram but I have no clue how to read it.
Old May 4, 2007 | 04:29 PM
1eye's Avatar
Wiring
working on it buddy, have it up by late tonight or 6 AM. {lots on the go} 1eye
Old May 4, 2007 | 05:50 PM
Yota Tony's Avatar
1eye, thanks.
I just picked up a new harness from a local yota place and the same wires where snipped as what's snipped on my current harness, he said run them to the battery.
Old May 5, 2007 | 03:53 AM
1eye's Avatar
Wiring
Pictures of wiring diagram are ready. Sorry, its to big to post here. [8.25MB] BUT, if you PM with a IP address that will except a file that big, I'll shoot it out to who ever needs it. 1eye.
Old May 5, 2007 | 05:50 AM
My814x4's Avatar
Here are the wires on our 81 4x4
80Truck
Oct 12, 2025 07:25 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
ToyoToler
Aug 8, 2015 08:43 AM
Daneums
Jul 28, 2015 11:57 AM
TDonkey
Jul 26, 2015 10:14 AM
