Pre 84 Trucks 1st gen pickups
what is needed to swap a 22re into my 83?
Old Mar 12, 2006 | 04:21 PM
83beater's Avatar
As you can see in my sig, I have an '83 with a 20r and a 4 speed. I like the idea of having fuel injection not to mention a little more displacement and an extra cog with a 5 speed. What needs to be changed to accommodate this engine?
Old Mar 12, 2006 | 05:41 PM
kyle_22r's Avatar
the wiring and fuel routing will be the hardest part. your truck rolled off the line with a 22R and 5 speed, so you've been cheated by a previous owner by the sound of things.
a 22RE and *early* 5 speed('81-83) is a direct physical bolt in(have to wire the computer and sensors, and run hi pressure fuel lines and pump for the EFI), a better, stronger late model 5 speed needs to have the crossmember relocated back about 4" and the drivelines resized.
Old Mar 18, 2006 | 03:57 PM
slacker's Avatar
in my opinion ... the earlier style (84) is the best to install .
I did one just a while back
and it actually was quite easy ... because of the early style , the speed sensor is not necessary , If you go with the newer 85-88 / 89 The speed sensor is incorperated in the speedo , and will need to be included .
With the earlier style , there really is only about 7 wires , and 2 relays ... quite simple ... the hard part is finding one ...
Old Mar 18, 2006 | 06:45 PM
kyle_22r's Avatar
actually wasn't the speed sensor only used on the '89-95 trucks? the trucks didn't get an electronic speedometer until '92 or '93.
Old Mar 19, 2006 | 06:54 AM
slacker's Avatar
mostly on the automatics , or maybe it only the autos , but book shows it in the speedo from 85 up ...
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
BigArt70
Jun 30, 2015 09:51 PM
LSUMatt1514
60
Oct 10, 2003 12:30 PM
HALMAN
Jun 14, 2002 09:02 PM
