Pre 84 Trucks 1st gen pickups
What is my problem?
Old Feb 20, 2008 | 01:47 PM
offroadohio's Avatar
What is my problem?
Here is the situation, I have a 1981 RV engine in my 84 pickup.
It had a really bad idle, when I could get it to idle.
I put plugs wires, cap, etc on it with no change. So I swapped the timing chain out, becuase someone suggested that.
I got it all back together today. It runs the same. I put a timing light on it and set it at 10btc
Shortly after the video was takenall it just shut off. I hit the key it cranked, hard but then fired up, I revved it to about2k, it bogged way down and died,
now it wont crank, and I cnat get it to spin, I'm fairly certain the thing locke dup, but what could have cuased it?
Old Feb 20, 2008 | 02:26 PM
rowdy235's Avatar
have you tried pulling the plugs?
Old Feb 20, 2008 | 02:40 PM
Put all new plugs, wires, cap, and rotor button on it already. All of the old plugs came out looking ok.
Old Feb 20, 2008 | 05:22 PM
red neckerson's Avatar
did this happen slowly or was it running good,and suddenly start running bad?
i would check the fuel filter,fuel pump,and make sure you dont have a real bad vacume leak.use starting fliud just to see if it aint a feul problem.
Old Feb 20, 2008 | 05:26 PM
infiltrator's Avatar
maybe its the video, but it sounds like you got some bad knocking on your engine. any cel?
Old Feb 20, 2008 | 06:29 PM
84sr5yoty's Avatar
Sounds like the EGR valve is stuck open.
Old Feb 20, 2008 | 06:47 PM
rowdy235's Avatar
I was referring to pulling the plugs and cranking it over, you said it didn't crank at all?
Old Feb 21, 2008 | 06:16 AM
No cel, but its an 81 engine in a 84 truck with a bunch of non hooke dup wires, and vaccum lines plugged off. The guy claims it did it slowly, already changed the fuel filter aswell. Havent pulled the plugs yet to see if it'll turn over without them.
Doesnt sound like there is a knock when runing, there was a faitn rattle like the timing chain to begin with thats why I changed it out, it was still there after I changed it.
SubiKing
Aug 21, 2021 03:57 AM
theking11863
Mar 19, 2016 09:36 PM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
