Welded my rear Diff (pics)
Here's mine. I used an old set of spider gears from a friend who had quick lockers installed. The extra spider gears gave a lot more surface area for welding. I think the plate is a good idea, too.
Looks solid, the extra spiders look nice too, because they can mesh in the gears to give that added strength once welded..
I keep talking myself out of welding the front diff. I know it will give a ton of traction, but i'm running with no power steering and wide tires. Might be best to save up for a Detroit and power steering setup.
I want to weld my rear diff sooooo bad, but my truck is a DD and I drive 65 miles round trip to work 5 days a week, I take the interstate the entire way to work, do you guys think it will eat up my tire too bad?
#26
hahaha hell yea!!!, i think im gonna do it!!! I have an uncle that is very good at welding but all he has is an arc welder do you think it'll be too messy?
#27
If its a DD i had a welded rear and couldnt stand it. Its whatever you think though. 4.10s welded in rear just puttering around town was no fun. Drove straight and true down the highway no problem.
If you do 90% freeway driving....weld it.
#29
I welded my rear (only) in my 80 2wd and turned that little sucker into a drifting longbed! my dork friends with 240sx's thought it was awesome i could out drift them with my pickup. The benefit was when they were stuck for the winter, i put on some snow tires on steelies and went pretty much anywhere too. had it like that for almost 3 years and didn't really notice any adverse tire wear
#30
thats awesome, my unlce is gonna weld mine monday
#32
From: where the left turn should have been taken, NM
hahah that made me laugh...drifting with a longbed thats awesome!
i welded my rear diff on my cherokee and i loved it! i liked hearing the skt skt skt skt arount the turns haha. the little bit of tire wear is well worth it i think. ill be welding the 79 very soon...probably front and back
and good idea with the plate on the spider gears!
#34
a welded front diff with only one hub locked in will break stock axleshafts and hubs, a limited slip is way easier on things, but if u have chromoly longs with hub gears, u will be fine being welded with one hub locked.
jerusry
Oct 19, 2015 05:28 PM
jon.r
Jul 11, 2015 03:34 PM
crashburnoveride
Jul 10, 2015 06:39 AM
