Pre 84 Trucks 1st gen pickups
V6 front calipers on 83 solid axle
Old Feb 28, 2011 | 10:43 AM
waskillywabbit's Avatar
You and I both know you don't need a damn press to remove/install wheel studs.
It's like you shaving one of your sheep with a lawnmower.
I've removed/installed hundreds with a brass drift and hammer and never busted/cracked a rotor.
:wabbit2:
Old Feb 28, 2011 | 05:51 PM
Nimyad's Avatar
Originally Posted by DeathCougar
A press to remove the wheel studs properly.
*NOTE* PROPERLY. Not the Alabama redneck hillbilly way
yup, my studs were pretty stuck in there. almost maxed a 8 ton jack on a few of them. same with putting a few of the new ones in there.
Old Mar 5, 2011 | 05:47 PM
ToyoTech559's Avatar
didnt wanna start a new tread. im bout to redo my front knuckles and gonna order new rotors. can i get the upgrade FJ60 vented rotors with stock set up till i can find a set of v6 calipers. thanks
Old Mar 5, 2011 | 05:51 PM
No, vented rotors will not work with SFA calipers.
:wabbit2:
Old Mar 5, 2011 | 06:13 PM
  #25
oh, thanks
so if i go v6 calipers, which rotors should i get or can i just use the ones i got
Old Mar 5, 2011 | 10:25 PM
  #26
truckman1966's Avatar
Jesus.....
Old Mar 5, 2011 | 10:38 PM
  #27
DeathCougar's Avatar
Originally Posted by truckman1966
Jesus.....
I Lol'd. But did you have anything constructive to add or????
Old Mar 5, 2011 | 11:11 PM
  #28
thanks for the lol and i'll keep it in line. just wanted to add that the front brake combination has been explained a few times in the thread alone already.
Old Mar 7, 2011 | 07:21 AM
  #29
js894x4's Avatar
V6 calipers. V6 Pads. FJ60 Rotors. Wheel Spacers. 2 Hours of your time on a Saturday. that's all you need to do this swap.
i think there is a 1/2 off at the junk yards coming up so i will go hunt for the parts i need not too sure if i will be able to find an (edit)fj60. but i will sure try. already have the 1.5" spacers.
Old Mar 7, 2011 | 08:17 AM
  #30
Hadmatt54's Avatar
If your truck is a solid front axle, you will need
2 x 1981-90 fj40 rotors some FJ60 &BJ60's had the same rotors
2 x 88-95 V6 calipers casting # S12W
12 longer wheel studs to bolt the 11/2" wheel spacers on. Standard studs are M12 x 1.5 pitch x 44mm. long, longer aftermarket studs are available.
Old Mar 7, 2011 | 08:57 PM
  #31
thanks, im about to redo my front knuckles and debating if i wanna spend another ~500 to upgrade calibers, rotors, and master cylinder
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
gieselman
Oct 12, 2015 01:34 PM
Scotto6591
Sep 1, 2015 03:24 PM
scottyg486
Jul 19, 2015 05:34 PM
